Can a fire exit be used as daily entry point?
  • 4 weeks later...
  • Replies 138
  • Views 120.9k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
At a place of business I work at, the staff entrance has always been designated as a fire exit in all the years I have been there. To enter when premises is closed to the public, we call a number and a manager let’s us inside. To exit, we press a button and the door opens for us to leave. There is signage on the outside of the door saying it is a fire exit. Recently management have decided it is not a fire exit and is being manually locked whilst the building is still occupied. Is this legal?
Without a survey it is impossible to say what MoE is required, it all depends on the layout of the premises.
Not without a fire risk assessment that is suitable and sufficient and by a competent person justifying why means of escape is still acceptable without it, usually based on the guidance here: https://www.gov.uk/government/collections/fire-safety-law-and-guidance-documents-for-business
  • 3 months later...
can someone help
i live in a warden controled building and i have to carry a 15kg battery out to my car for my boot scooter now at the side of my door there is a fire exit which i have been using for the last 3 years to carry my battery and shopping back into my flat. due to being disabled i can,t walk the long way round, yet i,ve been told i can,t use the fire exit anymore to exit the building.
can you help
It is my understanding that a final fire exit door can be used as an entry if is has the correct external unlocking device, if the door only has the quick release push bar or push pad then they should only be used for exit when needed and not for regular egress from a building
A single story club with a fire exit hallway approximately 14 ft long 6ft wide.are we allowed to hang pictures on the walls.
It is often done in such premises and probably without significant detriment to fire safety. Where done, I would agree with MN above and also say frames should be secured with mirror plates or similar to prevent them being dislodged.
However, it doesn’t seem logical for Building Regulations to require fairly stringent spread of flame characteristics for walls in escape routes only for someone to go plastering them with all sorts of detritus.
  • 6 months later...
Does a door that is the only entry and exit door to a flat need to be a fire door? The flat is on the second story and is accessed by fire escape metal stairs. Thanks
  • 7 months later...
A large place of assembly has two fire exits. To permit the maximum number of persons attending events (approx 200), the main entrance has be included in the calculation for the number and width of fire exits. Do the main entrance doors have to be rehung to open outwards?  I would appreciate any response.
Usually, yes unless secured in the open position at material times, especially as most guests will go back out that way even if they pass a fire exit on the way.
Much appreciated Anthony.
