How do I know if my CO alarm went off because of Carbon Monoxide?
We have a fire/ CO2 detector combined and this morning it went off. It first beeped and and said fire and then beeped again and said danger CO2 and quit. It was a constant beeping, and it hasn’t done it again yet as of 30 minutes ago. Could this mean that the batteries are getting bad?
  • Replies 238
  • Views 542.5k
  • Created
  • Last Reply
Top Posters In This Topic
For future reference:
CO2 is carbon dioxide and is found in CO2 fire extinguishers, also it is what makes drinks fizzy.
CO is carbon monoxide and is often found in improperly burnt materials. (Wood, gas, oil, coal)
Both are colourless gasses, carbon dioxide is heavier than air, and carbon monoxide is roughly the same density as air.
Carbon monoxide detectors can be activated by other gases, even newly laid screed has been known to activate a CO detector.
There is such a thing as a CO2 detector, they also detect other gasses and are used in some industries (They are also some what expensive)
I had a gas safety annual check and the engineer was shocked that there were no dates on the CO alarms, he still signed the form to say they were in date and working, I have scince learned that there is no way of testing if the sensor is faulty if the batteries are still working it will still flash green if the sensor has gone. I rang him to ask why he ticked they were in date if there was no date on them and he rushed round the next day to give me a new paper saying they were put of date? He is a friend of my landlady and condemned my gas fire as he said it had never been checked because on installation it was silliconed in and the seal hasnt been broken, meaning the flu has never been checked in over ten years, he said he couldn't give me a new form until he had the old one back that he lied on, I told him I had shredded it but I didn't so now I have the one he lied on and another which he didnt the following day. How do I and where do I report him for lying in the first place?
  • 4 weeks later...
Our carbon monoxide akarm went off about 4am. I woke up and noticed I forgot to turn off the stovetop (gas). I immediately turned if off, and opened the front door by the stove and opened some windows. I woke up and checked to make sure my brother was awake/breathing. How long does it take to air out? My brother, went back to sleep. How do I know when it will be safe to sleep again? How long does the carbon monoxide take to disapate?  He's an essential worker. I keep checking on him. I won't sleep tonight.
There is no answer to this problem it depends on so many parameters, check the internet on the best ways to ventilate a domestic premises.
Hello, I have 3 carbon monoxide detectors in my house, one in each bedroom and one downstairs in the kitchen, where the boiler is. One of the detectors that’s upstairs suddenly went off earlier today, beeped 4 times, paused then beeped another 4 times and that went on for about 2 minutes. I moved the detector from the bedroom to the kitchen and it stopped beeping after some time. I called 999 and left the house and waited for the emergency services to come, and when they did they checked all the detectors and then gas services checked for CO levels and everything was fine. So did the CO detector go off because it was faulty? Later when I went to place the detector back in the bedroom it didn’t go off again. Should I be worried?
Stand alone carbon monoxide detectors detect carbon monoxide and should be installed near something that may give off carbon monoxide, such as a boiler, there is no point in having them in a room where there is no means of producing carbon monoxide.
It has been known for a carbon monoxide detector to activate at what appears to be random, and only for a short time (Such as happened to you) If this happens and the carbon monoxide detector stops and does not repeat then it is probable that there was a small pocket of carbon monoxide that has since dissipated, and is nothing to worry about.
If a carbon monoxide detector activates for a short time then stops, then repeats several times I would take the detector outside and if it does not stop, replace the detector, if it does stop put it back where it was, if it does not start, there is nothing to worry about. If it starts again open all the windows and look for a source of carbon monoxide (boiler) Get the boiler checked as soon as possible
I would also suggest that you have smoke alarms in each bedroom, not carbon monoxide alarms  as smoke alarms would be more useful, and preferably have interlinked smoke alarms, this can be done by either hard wiring them or radio interlinked. Either way smoke alarms should be replaced every 10 years and carbon monoxide alarms should be replaced every 5-7 years (Some last 5 years, some last 7 years.)
Hi, my Carbon monoxide detector beeped a couple of times, then read 218, then 888 then 0....is this something i should be alarmed about??
Its plugged into the electric outlet.  Thank you!
  • 3 weeks later...
My CO detector started beeping every after 30-35 seconds for about 20 times. This happened in 3 consecutive days.
I replaced it with a brand new CO detector (same brand). Just after about 5 minutes of it being plugged in, it started beeping in 30-35 sec interval.
Within the hour, I replaced it with yet another CO detector (different brand). Same thing happened, quick beeps every after 30-35 seconds for about 2 hours.
Right now the CO detector is quiet. Any ideas why this is happening?
Thanks for responding.
Hi, clearly you have either carbon monoxide or other gases in the vicinity that trigger the CO alarm.
The first step has to be to search for a source of carbon monoxide. Do you have gas/oil/solid fuel appliances? Do your neighbours have such appliances?
If this is not the case you need to check whether you have acid-lead battery chargers nearby or whether there is fresh floor screed. Both create gases that can trigger CO alarms.
Most likely the CO alarms are doing their job and warning you of this dangerous gas. You need to leave the building and get a specialist to fix the issue. Further information about CO dangers can be found on https://www.safelincs.co.uk/carbon-monoxide-information/
On 23/11/2017 at 23:21, Guest Janiebsmith said:
We've just had an extension built and they came to do the floor screed today. Our CO detector went off late afternoon and my husband called British Gas who have since been and disconnected the gas supply, however, the detector has gone off again. A friend of a friend had the same experience when their floor screed went down - has any one else heard of this happening?
We have just had the same, screed was laid this morning, CO alarm was going off (which was lying on top of the water cylinder next to the boiler) albeit covered in a thick layer of dust.  Once a gas engineer had been out and disconnected the gas the supply we went to bed where the alarm went off again in the freshly screeded room!
I had my boiler fixed yesterday and had my co alarm replaced. Tonight it was laying flat and went off, it stopped as I got to the stairs but without touching it. I’ve taken it outside and put it back where it was but upright and it’s not going off again, should I be worried and get my children out of the house?
I just purchased a new carbon monoxide/fire alarms a couple months ago. Today the alarm went off in my upstairs bedroom and upon further research discovered it was carbon monoxide alarm. However no other alarms within the house are going off and my oven is off and this is summertime and it’s 100° outside so I don’t think it would be going off for that reason. I brought the alarm downstairs and now it’s not going off. I’m not sure what to do I’m wondering if I should even sleep in my bedroom   All I did was clean out my refrigerator upstairs that’s inside the bedroom that’s it.
Put the alarm back in the room from where it came and leave it for a while, if it does not go off, press its test button to ensure it is working. If it only goes off when you press the test button you have nothing to worry about. If your carbon monoxide alarm does go off again something is giving off carbon monoxide and you will have to investigate further.
Carbon monoxide is colourless and odorless so you can not see or smell it, and it is not un common for carbon monoxide alarms to go off when concrete screed has recently been laid.
Hiya my alarm has recently gone off too and my partner said he wanted in front of it a small amount then it actually stopped I'm really worries about what to do help
Assuming your carbon monoxide alarm has only gone off just the once, and it is NOT near its expiry date (Check the unit itself for a date, the average expected life is 5, 7 or 10 years, depending on make/model) and it still works when you press its test button, then you have nothing to worry about.
  • 3 weeks later...
Why does my carbon monoxide go off when the wood burner was lit
My CO2 Alarm went off yester, about 4 times, first time is was a constant alarm sound. I reset the reset button and it stopped, it went off again about 2 hrs later as beeps, I changed the batteries, it went off again (beeps) after about another 2 hrs, changed the batteries again as the ones i put in first time were not boxed, so may have been old. This time I put in brand new ones and again the alarm sounded as beeps about 2 hours later. This time I called the Gas and the guy who came out got very high readings (500) for CO2 down the back of the House Burglar alarm control panel which is situated in a small utility room as is the gas boiler. No CO2 was detected anywhere else and his CO2 Alarm also went off after a while. He took the fuse out that powered the house burglar alarm and the CO2 levels dropped to zero eventually. He put the gas on and left it on for 20 minutes, taking more readings and they remained at zero. The conclusion was that the House Burglary Alarm control box was the cause of the CO2. I had the House Burglar Alarm guy out this morning and he rubbished what the Gas guy said and says it is up to me if I want a new House Burglar Alarm control Box and settings box. Has anyone ever come across this before,?
