March 25, 20206 yr comment_16739 Check out page 82 of Offices and shops guide and there are other documents. Report
June 28, 20205 yr comment_17399 Will it require Council permission to alter a kitchen window to an essential fire escape door to regulation built escape walkway to garden. Thank you in anticipation of answer. Report
June 10, 20215 yr comment_20406 Hi im after some advice please, there is a building renovation next door to me, between us is a walkway on my boundary which is a fire access for the block I live in. The developer has started cutting an opening for a window which is on this walkway and to the side of my front door (about 5 footsteps between my door and window) the window is due to have top opening which if anyone was to use walkway would be knocked out. The party wall surveyor I instructed wants nothing to do with this now he signed the original paperwork which showed windows elsewhere is this legally allowed? thank you Report
June 11, 20215 yr comment_20419 If it's still under construction I suggest you contact your Local Authority Building Control department to have a look. Report
June 15, 20214 yr comment_20462 Hi A old house turned into student accommodation has a concrete enclosed staircase escape with two fixed georgian wired glass windows in timber frames. We want to change the windows. What do they need to be please? Many thanks Neil Report
June 17, 20214 yr comment_20487 Depends on where they are and why. If they are Georgian wired for impact protection then suitable toughened/laminated safety glass, if for fire then it needs to be 30 minute fire resisting glazing (which due to advances in technology over the last couple of decades can be clear without wires). Toughened/laminated safety glass is not fire resistant as a matter of course it needs to be specified as both.https://www.ifsecglobal.com/fire-protection/guide-to-fire-resistant-glass-and-glazing/ Report
July 14, 20214 yr comment_20796 Hi We have a warehouse that has an internal office on the first floor. What would your recommendation be for the glazing in the windows overlooking the warehouse? Would you suggest they are fire rated to prevent spread of fire into the offices? Is there a standard that should be adhered to for internal glazing in such a situation? Report
July 29, 20214 yr comment_21017 This would all depend on the results of a FRA it may need to be upgraded to half hour or not depended on the results of the FRA. Report
August 31, 20214 yr comment_21457 Can a final exit door under and external escape stairwell be fully glazed? My though is no it cant. The minimum it must be for a two storied building is 1 hour. Report
September 1, 20214 yr comment_21471 The door sounds like it should be FD30S, as long as the door and glazing conforms to the standard then yes. Report
September 20, 20232 yr comment_38664 Hi, after some advice. I have an external balcony type escape route on the first floor, four flats on this floor. Flat entrance doors and windows along the balcony, the windows are 1100mm from balcony floor. Should the windows be FR? If so, only the glazing could be changed as I don’t think the residents would be happy to have fixed windows. Any help would be greatly appreciated. Report
September 20, 20232 yr comment_38669 No - that's why they are 1100mm from the floor - that is set in Building Regulations on the assumption people can crawl past the window (not that they would usually need to in a stay put block), the doors should still be fire doors though. Report
October 5, 20241 yr comment_45014 Same topic but I'm working on a new external firestair way on a nightclub which will run along side two windows , I know I have to fit fire rated glass 30 mins the question is do I have to change the frames to fire rated rated also? Jon Report
October 7, 20241 yr comment_45047 Can I ask, what is the point of replacing the glazing if it will fall out of the frame in a fire? The frames will need to be fire rated Report
October 16, 20241 yr comment_45225 Does anyone know please if you can get 30 minute fire resistant PVC windows and glass and if so where from at a reasonable price? Based in Devon ideally. Thanks Report
October 16, 20241 yr comment_45242 https://window.rehau.com/uk-en/pvcu-windows-doors-composite-curtain-walling/pvcu-rehau-windows/fire-rated-windows Report
