June 12, 201510 yr comment_7622 Can Anyone tell me the right way to apply passive fire paint on a steel structure? I applied the regular way but when torched, no intumescent comes out and surface and surroundings get really hot. What to do? Report
June 12, 201510 yr comment_7624 Since you have said paint, and I don't, what do the instructions on the tin say? Report
June 13, 201510 yr comment_7630 Have you purchased intumescent paint designed for structural steelwork and have you follow the manufacturer's instruction to the letter? Report
July 8, 201510 yr comment_7757 I'm thinking you should be using the services of a competent passive fire protection contractor for this work, you appear not to have the knowledge required - it sounds like you are using standard fire rated paint rather than a structural steel work intumescent coating! Report
