June 15, 201214 yr comment_2238 Could you please tell me if there is a maximum gap size between the fire door and frame after which the intumescent seal will not work. I have been told by a carpenter that this is 3 mm. Thank you Report
June 15, 201214 yr comment_2240 That is the average gap and is documented in British Standard BS 8214:2008 Code of practice for fire door assemblies. 9.5.2 Clearance gaps Failure of fire-resisting door assemblies under test is very often due to burn-through at the clearance gap between the door leaf edge and the door frame. Doors should be hung to give an equal gap across the head and down both jambs. A typical gap to achieve good fire performance is between 2 mm and 4 mm. NOTE Guidance on operating gaps for timber doorsets is given in BS 4787-1 and BS 5588-112). Report
June 26, 201213 yr comment_2276 I recently attending a fire risk and safety management course and was advised to obtain a gap gauge with a mirror fixing to be able to check fire doors. I have not been able to find such a unit and wondered if you might be able to advise where this course be purchased? Any information would be appreciated. Many thanks. Roz Report
June 26, 201213 yr comment_2277 Hi Roz Safelincs provides these fire door gap testers free of charge. Just email service@safelincs.co.uk Harry Report
July 20, 20178 yr comment_10546 Thank you. I have today sent in an Email for 3 of your finest door gap testers!!!! Report
July 21, 20178 yr comment_10549 They are different to the BWF ones but still look useful and handy! Report
October 13, 20178 yr comment_10942 Hi Martin, yes it is, just email service@safelincs.co.uk Harry Report
August 12, 20205 yr comment_17710 Hi Just come across this I'm looking for 5 Fire Door Gap cards could I order them here Report
August 13, 20205 yr comment_17716 Hi Nicola, they can still be requestyed at service@safelincs.co.uk Harry Report
January 6, 20242 yr comment_40449 Hello,How do I solve the gap on frame where the lock plate is my fire door has recently failed because there is a gap between intumesant strip and door latch plate measuring 180mm Report
January 8, 20242 yr comment_40495 Its OK. The intumescent strip & smoke seal may be interrupted at lock and hinge fixing points. If the inspector/assessor disagrees, ask them to provide specific evidence that the seal must be continuous and uninterrupted. Report
