May 23, 20224 yr comment_26094 Hi Is it possible to lip the top of the frame to close the gap at the head of the doors to the frame on a nominal door? thanks Report
June 8, 20224 yr comment_26653 Its a debatable thing as nominal fire doors are a compremise and if a lot of work is required they should be changed for a full spec fire door. Report
June 13, 20223 yr comment_26814 Be careful using timber lipping. There are requirements that timber lipping has a minimum density, min and max dimensions and that a suitable adhesive is used. Report
