March 17, 201214 yr comment_1853 Morning Our smoke alarm started bleeping last night and kept the dog awake! When i checked this morning i could not change the battery. Its connected to mains and its a kidde firex. Anybody can help? Paul Report
March 17, 201214 yr comment_1854 hi Paul, you are lucky we are in the office :) There is a range of simple videos to see how the Kidde Firex smoke alarms can be taken of the wall and how the battery is changed. How to replace the backup battery in a Kidde 4973 optical smoke alarm Replacing the backup battery in a Kidde ionisation smoke alarm 4870 How to replace the backup battery in a Kidde 4899 heat alarm I hope this helps Harry Report
December 30, 20169 yr comment_9606 Wont be buying alarms like this taking the wires off is nearly impossible no need to make this so complicated Report
December 30, 20169 yr comment_9607 Using a plug to connect to a smoke detector is not only easier than terminals, it is safer and ensures that the detector is connected correctly when reconnected / replaced. I don't find removing a plug "complicated" Report
April 14, 20179 yr comment_10069 My alarm started beeping. I changed the battery according to your video and it is still beeping. What next? Report
April 17, 20179 yr comment_10073 Hi Annie I suggest two steps: 1) check the replacement date for the alarm. All mains powered smoke alarms should be replaced after ten years as they can become erratic. 2) make sure there is not a carbon monoxide alarm nearby that has a low charge battery and therefore beeps. These beeps can be very deceiving. To find out, take your Kidde alarm off the ceiling, remove the battery, press the hush button to drain any charge left and listen out for a few minutes. If this leads to nothing, you will have to replace your alarm. Here a list of Kidde replacement smoke alarms Harry Report
January 9, 20197 yr comment_13264 Hi I have been in a New build for just over two years and have a Kidde 4MCO alarm. It was installed in late 2016 and has just started beeping every 60 seconds. From what I am reading it sounds as if the battery is at end of life, but isn't replaceable. Is that correct and, if so, should it be covered under the warranty? Report
January 9, 20197 yr comment_13269 Hi, yes, this Kidde CO alarm has a six year warranty. However, you need to make sure that the power supply to the CO alarm is actually working, otherwise the alarm will indeed drain and start beeping. Harry Report
July 21, 20196 yr comment_14692 I have tried and tried to get the power plug out of a 1240C and I can not budge it, I have even tried to prise it up with a screw driver! What is the correct way to do this? I am trying to replace it as it is over 10 years old. Thanks in anticipation Report
July 22, 20196 yr comment_14698 Hi, the closest instruction video for a removal of a Kidde Firex smoke alarm is here Harry Report
October 25, 20196 yr comment_15589 On 21/07/2019 at 12:01, Guest Bumps said: I have tried and tried to get the power plug out of a 1240C and I can not budge it, I have even tried to prise it up with a screw driver! What is the correct way to do this? I am trying to replace it as it is over 10 years old. Thanks in anticipation Hi I’m having the same problem! In the Video it looks like he is squeezing something but there isn’t anything to squeeze!! Did you figure it out? Report
November 1, 20196 yr comment_15632 I would suggest you contact the manufacturer to find out, but it could be more serious like the pins have oxidized and there would be no way of removing the smoke alarm other than removing the wiring and fitting a new base plate with smoke alarm. Report
May 11, 20206 yr comment_16996 I am trying to replace the battery in the Kidde Firex KF1 smoke alarm and cannot get access to the battery compartment as the cables are almost impossible to remove any help! Report
May 11, 20206 yr comment_16997 looks like the tab needs to be lifted with a flat screwdriver, until the battery door can be opened Report
May 16, 20206 yr comment_17022 Check out https://www.bing.com/videos/search?q=changing+battery+in+Kidde+Firex+KF10&qpvt=changing+battery+in+Kidde+Firex+KF10&FORM=VDRE Report
July 30, 20214 yr comment_21055 Hi my carbon monoxide alarm(4mco) beeping show low battery its 3 day since I instal Report
July 30, 20214 yr comment_21057 If it says low battery then have you tried changing the battery? It may be the device has an old battery from new. Report
August 5, 20214 yr comment_21122 i have one and despite instructions to insert a flat blade screwdriver and pull cover - no it doesn't work - bleeping for 4 hours now and can't get cover off - not designed for old fingers that's for sure Report
August 8, 20214 yr comment_21167 Hi There is a help video about how to remove the Firex/Kidde alarms which should apply Harry Report
