August 2, 20214 yr comment_21084 Do steel doors need smoke seals? There is a seal around the door set at my work place but a seal is missing on one side. Is this a smoke seal or acoustic seal. Report
August 4, 20214 yr comment_21112 The requirement for smoke seals is based on the needs in terms of fire strategy at the building. For example, fire escape routes would benefit greatly from restricted spread of smoke as would sleeping areas. Having the door type (steel/timber) alone reveals nothing about any requirement for smoke seals. Report
August 4, 20214 yr comment_21116 As said it depends on location. Protecting an escape route is a common situation where a door would need smoke seals. Report
