April 9, 20215 yr comment_19775 If a house has three storeys and it has been converted into flats, then I understand that it will need a Grade A fire alarm system. What about if there are three storeys, but there are only 2 flats. I.e. there is a flat on the ground floor, but the two upper floors are just one (2 storey) flat. They may even have their own private staircase from the ground floor (behind a closed fire door), which means that the only communal area is the ground floor lobby. Does this building still need a Grade A alarm system? Thanks Report
April 14, 20215 yr comment_19821 I am assuming the original staircase serves the first and second floor; therefore I think you would be considered dealing with a building of three storeys, according to the guide and would need to opt for the Grade A and Grade D systems. Otherwise you would have to argue that it should be considered a two storey building because it is a flat and a maisonette I am not sure you could get away with it. Check out HOUSING – FIRE SAFETY Guidance on fire safety provisions for certain types of existing housing. Report
April 27, 20215 yr comment_19946 What about a three storey building where the ground floor is a commercial unit, and the two upper floors are residential flats - and they have a separate entrance then the shop. Would this still require a Grade A system - because it's 3 storeys high, or do we ignore the shop and since the residential units only occupy 2 storeys (plus the staircase to ground level), a Grade D system would suffice? Report
April 28, 20215 yr comment_19962 That is a matter of personal interpretation, you will hear different opinions of both A & D, plus if the premises are a conversion that comes under selective licensing the council will have their view as well. I've seen Grade A more often than not in this situation. Another factor that could influence matters is the separation between the shop & flats - if inadequate thus requiring linked systems you are looking definitely more like a Grade A system. Report
