November 7, 201213 yr comment_5041 Hello We have 2 emergency lights in our office which I assumed the landlord was looking after. The landlord has now been in touch to say we need to look after the emergency lighting. It seems that by law we only need emergency lighting if there is a serious risk present in the event of loss of power. I don't believe there to be a risk and so don't feel there is a need for the lights. Can I leave the lights in the office untested or do I need to remove them? Many thanks Tom Report
November 7, 201213 yr comment_5042 There is one sure way to check if you should keep your emergency lights, turn all the other lights off, can you see your way out? Report
November 8, 201213 yr comment_5051 Tom how did you do your assessment if the two emergency lights are still functioning or were they disabled. Report
November 10, 201213 yr comment_5052 To see if your emergency lighting is required you can check out the government guide http://www.communities.gov.uk/publications/fire/firesafetyrisk2 which will give an indication There is also a useful guide http://www.safelincs.co.uk/introduction-to-emergency-lighting/ Report
