October 4, 20224 yr comment_29948 Could anyone advise me on the regs regarding the fitting of Geofire Doormouse Wall Mounted Electromagnetic Fire Door Holders, e.g cables used, containment, activation etc Report
October 5, 20224 yr comment_29959 Forgive me if I am in error, but you have already asked the same question earlier (See your reply from Anthony B Click here) but this time you seem to be asking how to do the job in terms of what you can or can not connect to a sounder. Most fire alarms nowadays are addressable, you would need to add an interface which is compatible with the fire panel, which is then connected to the appropriate alarm loop and the door release is connected to the interface, then you tell the fire panel when you want the interface to operate. (The panel will also monitor the interface.) Fire alarms have become specialist, long gone are the days with twin and earth to call points and pyro for mains sounders. Report
October 5, 20224 yr comment_29968 You really need a copy of BS7273-4 or an industry guide to it - too much to post here! Report
