June 6, 20224 yr comment_26564 Hi Can you please assist What is classed as a small gap between door and frame to allow intumescent seal to work Report
June 13, 20223 yr comment_26819 The applicable Standard is BS 8214: 2016 which recommends a maximum of 4mm and minimum of 2mm. Report
