December 8, 20205 yr comment_18717 should the indicator or test button, turn off when power is lost? Report
December 10, 20205 yr comment_18749 Yes, the green (or red on older fittings) LED light indicates there is a live mains supply entering the charger - if the mains goes off, the light goes out. Report
April 5, 20224 yr comment_24885 i need to have the indicator emergency light, is it a seperate piece? Report
April 8, 20224 yr comment_24968 If you mean the LED that indicates there is a mains supply entering the fitting and the battery charger is active then it's not an individual part - you need a new fitting. Report
