Guest cri Posted October 26, 2024 Report Posted October 26, 2024 On 08/07/2024 at 10:21, green-foam said: Sorry for the "late reply" (The way this forum works, all new posts are held for review and released on a Monday) The Deta 1151 is obsolete and has been for a number of years. As they have no user serviceable parts, I would suggest you change it, as you are changing one, you should change all of them. I recommend the Aico brand Click me as these have a baseplate with dedicated (colour coded) space for the cables, very easy to install, have been around for many years (with no change in baseplate, unlike some.) On 08/07/2024 at 10:21, green-foam said: Sorry for the "late reply" (The way this forum works, all new posts are held for review and released on a Monday) The Deta 1151 is obsolete and has been for a number of years. As they have no user serviceable parts, I would suggest you change it, as you are changing one, you should change all of them. I recommend the Aico brand Click me as these have a baseplate with dedicated (colour coded) space for the cables, very easy to install, have been around for many years (with no change in baseplate, unlike some.) Thanks for the advice. Have I understood that the Aiko brand can be used as a direct replacement of the Deta 1151, avoiding the need for me to replace the baseplate? Not that replacing the baseplate is a big deal, but if I can avoid it, why not? If so, I guess it answers the question that has been on my mind - when replacing a wired interlinked network of smoke/heat detectors, must I stick to the same brand as existing units? I guess the answer is no, or is it "it depends"? And if so, what do I need to bear in mind? Thanks! Quote
green-foam Posted October 28, 2024 Report Posted October 28, 2024 On 26/10/2024 at 15:10, Guest cri said: Have I understood that the Aiko brand can be used as a direct replacement of the Deta 1151, avoiding the need for me to replace the baseplate? Hello Cri, you have miss-understood. I never said the Aico smoke alarm baseplate is compatible with the Deta Brand. I said On 08/07/2024 at 10:21, green-foam said: I recommend the Aico brand Click me as these have a baseplate with dedicated (colour coded) space for the cables, very easy to install, have been around for many years (with no change in baseplate, unlike some.) Other manufacturers change the design of their smoke alarm and change the design of the baseplate accordingly. Aico have changed their smoke alarm design (slightly) and brought out new alarms BUT they all use the same baseplate For clarification, I have attached a picture of an Aico baseplate and another brand of smoke alarm baseplate. When changing a smoke alarm that is interlinked with other alarms you should change all of them at the same time to the same brand as this avoids any compatibility problems and gives the assurance they will all sound when they need to. The other thing to consider is that most smoke alarms require an optional baseplate to be ordered, Aico alarms do not require this as it is included in the box and is part of the alarm. I should also point out that when mounted to their respective baseplate most smoke alarms are deeper than the Aico Quote
Guest My heat detector has gone Posted May 5, 2025 Report Posted May 5, 2025 Hi my heat detector has gone off, despite turning it off at the mains it still persists in going off. Is there anything I can do. Quote
green-foam Posted May 7, 2025 Report Posted May 7, 2025 The way this forum works, asking on a bank holiday Monday means your question does not show for a few days.🤐 Assuming you have not damaged your alarm, turning it off at the mains is not a good idea, since that means you will be making it run on its battery. You do not say how old it is, most smoke / heat alarms have an expected 10 year life after which they should be changed. Have you cleaned it (With a vacuum cleaner to remove any dust or insects?) As smoke / heat / CO alarms have no user serviceable parts, the only thing you can do if you still have problems is replace it. Quote
AnthonyB Posted May 7, 2025 Report Posted May 7, 2025 Heat detectors, by their very nature, rarely false alarm due to the fact they are unaffected by steam, aerosols, dust, insects, etc. It will be running on battery until flat and is most likely to be defective - you should replace it with a new one - you can take it down whilst still noisy and until you can get a new mains detector installed it's advisable to put up a cheap battery only detector to keep you covered. https://www.safelincs.co.uk/smoke-alarms/ Quote
