August 13, 20197 yr comment_14880 Hello: Can you kindly advise if there is a known problem with this alarm (batch: 17110-17326J). Supplied/fitted by a Brigade c one year ago, it's intermittently sounding full alarm (replace end Jul 2028), with no evidence of smoke and no other smoke/carbon monoxide alarms in the house sounding (inc another identical model - two were supplied). After the first false alarm it has been vacuumed of dust but is still sounding intermittently. This is NOT the low battery signal. Have asked FireAngel for replacement. Many thanks, Marcus Report
August 17, 20197 yr comment_14938 I think you have taken the correct action contacting the manufacturer and I would contact the fire service they may fit a replacement. Report
August 18, 20197 yr Author comment_14954 Tom: Thanks; FireAngel replaced under warranty. I guess it's faulty - just surprised about the spontaneous alarm. I don't know whether these are totally 'fly'-proof (midgies et al around in the summer)... Report
August 19, 20197 yr comment_14960 I doubt it as all manufacturers recommend vacuuming it out at regular times and if the filters were 100% effective this would not be necessary. Report
March 18, 20215 yr comment_19599 I have exactly the same problem. It was fitted in 2019 and has been fine since but now keeps sounding a full alarm until I turn it off. I’ve had to take it down. Will replace battery if I can and see if that works. Report
April 10, 20215 yr comment_19799 Change the battery, as the life is about one year, if it still gives problem contact the fire service. Report
August 28, 20215 yr comment_21439 I had a Fire Angel ST750 fitted by the fire service in June and today it has sounded approximately 4 times (not the sound of a diminish8ng battery). There is no smoke that I am aware of although I'm not sure how much smoke is needed for it to be activated? The first time it sounded was at 7:30am and again 10 mins ago (4.15pm). Could something be smouldering? Report
August 31, 20215 yr comment_21463 Smoke alarms very rarely false alarm, as yours has done so twice in less than 12 hours and it was only installed just under 3 months ago I would get in touch with fire angel, It should be covered under the fire angel 5 year warranty. Report
