May 10, 20179 yr comment_10149 Hi, I am trying to find legal documentation on the rules and regulations with placing a stairs to a fire exit outside a building. Thanks Chris Report
May 11, 20179 yr comment_10156 Contact your local Council Planning Department as there will be requirements with Planning Permission and Building Regulations. https://www.planningportal.co.uk/ Report
May 12, 20179 yr comment_10160 Although the approved documents do not include external staircase the Approved Documents especially ADM and ADK may still be appropriate and will at least provide you with some guidelines upon which you could base your detailed design. Also you should consider BS 5395-1:2010 and BS 8300. Report
October 21, 20214 yr comment_22045 My neighbour has an outside fire escape which has patio doors to it.is this legal Report
October 22, 20214 yr comment_22062 Why not? If it's the highest set of doors on the stair they don't need to be fire doors. Report
