March 7, 201610 yr comment_8644 I am trying to find the required dimensions for an external fire escape from a multi-storeyed house. Can you please advise? Building Regulations appear to deal with internal stairs and exits from a building. Report
March 9, 201610 yr comment_8652 Is it a house converted into flats or is it a single private dwelling house because it will decide which approved document should be used? Report
March 14, 201610 yr comment_8668 Use Approved Document B volume 1 if it is a single dwelling house and use volume 2 if it is a flat External fire escapes are staircases therefore use the same guidance as for internal staircases, use Approved Document K, Approved Document M and Approved Document B, for its design. However there are additional requirements, inspecting, testing and protection from the elements. Check out http://www.designingbuildings.co.uk/wiki/Stairs http://www.planningportal.gov.uk/buildingregulations/approveddocuments/ Report
June 19, 20178 yr comment_10311 Our house is one converted into five flats with an external fire escape. Approved Document K appears to require ALL staircases with open risers to have a vertical gap of less than 100mm. Is this correct? Report
June 19, 20178 yr comment_10331 If the escape installation predates ADK it doesn't have to be retrospectively changed if not fully compliant Report
June 21, 20178 yr comment_10340 Our house is one converted into five flats with an external fire escape. Approved Document K appears to require ALL staircases with open risers to have a vertical gap of less than 100mm. Is this correct? This is a new fire escape. Report
June 23, 20178 yr comment_10349 You should check it out with Building Control but it appears there should be no gaps for flats and you should not be able to pass a 100mm sphere between the open steps for dwellings. Check out https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/443181/BR_PDF_AD_K_2013.pdf page 6 Report
January 4, 20224 yr comment_23159 Hi, I need a walkway outside the first floor of a commercial building for emergency exits for 3 flats. Do you think I need planning permission for the walkways? Planners have no idea and want me to apply anyway but can't say if I do need one! Many thanks Report
January 6, 20224 yr comment_23191 This isn't a planning law forum, however if in doubt it's probably better to apply and not need it than the other way around! More important is the submission to Building Control for the work which you will have to do regardless of planning. Report
