November 12, 201411 yr comment_6856 I hope you can help me as I am receiving mixed information regarding furniture (dog beds) for pets. The cushion used in the bed can be non-fire retardant and the filling has to be fire retardant? So if we create a wooden bed which will be upholstered. Will the bed have to be fire safe? I am confused about which bit will have to be fire retardant when dealing with pets. Thank you very much for looking into this. Kirsten Report
November 13, 201411 yr comment_6859 I agree the cushion cover can be non-fire retardant and the filling must be fire retardant but what you are proposing is a piece of Domestic Upholstered Furniture. Which is defined as “furniture of any description which is ordinarily intended for private use in a dwelling and includes beds and divans (including the bases and headboards of both), sofa-beds, children’s furniture, cots (including carry-cots, playpens, prams and pushchairs and any other article of a like nature and use designed to contain a baby or small child), cushions, high-chairs, mattresses (of any size) and pillows, but does not include bedding or floor coverings (including carpets and mats) also furniture which is ordinarily intended for private use in the open air but which is also suitable for use in a dwelling”. Consequently I think your upholstered wooden dog’s bed fall within that definition and therefore will be subject to the full regulations, including the cover and filling. Check out http://www.firesafe.org.uk/furniture-and-furnishings-fire-safety-regulations-19881989-and-1993/and http://www.fira.co.uk/flammability Report
June 11, 20206 yr comment_17246 Hello, I was wondering of I could have some advice too. I am looking at making my own dog beds. But they will be soft beds only, filler and textiles cover. So do I just comply with the following: the cushion cover can be non-fire retardant and the filling must be fire retardant? I want to clarify that what I am making is not classed as Domestic Upholstered Furniture? Also what is the fire retardent safety standard for foam or fillers in the UK called? Just so I can make sure I reference this in my conversations with manufacturers. thank you abi Report
June 17, 20205 yr comment_17289 IMO your dog beds would fall under floor cushions and have to fully comply with the regulations. Floor cushions are considered to be any cushion supplied separately and not comprising an integral part of an item of upholstered seating. While not defined in the Regulations, it is commonly accepted that a floor cushion has dimensions which are greater than 60cm x 60cm x nominal product thickness. If there is any doubt over compliance with the Regulations it is recommended that expert advice is sought from the likes of Furniture Industry Research Association or check out section 11 of the guide. The guide Fire safety of furniture and furnishings in the home A Guide to the UK Regulations. Report
January 17, 20215 yr comment_19006 I want to create small pet beds. What regulations do I need to follow for these? I want to create more like mats on the floor. I have already created something similar but want to know what regulations I need before selling. Thank you Report
January 18, 20215 yr comment_19020 If there is no upholstery and you do not use a filler then it would not be subject to Fire safety of furniture and furnishings in the home A Guide to the UK Regulations and I am not aware of any other legislation in private accommodation. Report
December 29, 20214 yr comment_23087 Ive recently purchased two pet beds. Both are foam filled. No kite mark. Are these a fire risk. Report
January 7, 20224 yr comment_23210 The kite mark only indicates the item conforms to a British Standard and FFFSR labels are a different matter. As pet beds are usually designed to be used indoors I think they should be labelled with FFFSR permanent label but I cannot find anywhere in the guidance documents that indicate this. Report
July 25, 20232 yr comment_37658 No, you should never have fire retardant in ANY bed regardless whether you’re human or dog. It’s not necessary at all. Fire retardants in beds are toxic and are not good for you or your pet. Please don’t not purchase or have any products containing fire retardants. There are multiple videos that you can look up on YouTube or these links to articles: https://www.dogsnaturallymagazine.com/flame-retardant-dangers-dog/#:~:text=Avoid products with brominated fire,may contain toxic fire retardants. https://madesafe.org/blogs/viewpoint/product-profile-pet-beds https://www.berkeleydogbeds.co.uk/blogs/news/memory-foam-dog-beds-beware Please be aware and keep your pets safe! Report
July 26, 20232 yr comment_37684 I can't help but think that the person who asked the question has long gone since they asked in 2014, and the next person asked in 2020, then again in 2021. My point being this topic has been inactive for years, so pointless posting. Report
