Guest MoMcG Posted November 13, 2013 Report Share Posted November 13, 2013 How can you switch off power to a fire alarm panel? Is that in the fuse box or does there have to be a seperate switch? I have seen these with 'Fire Alarm - Do not switch off' written on them. Mo Quote Link to comment Share on other sites More sharing options...
Safelincs Posted November 14, 2013 Report Share Posted November 14, 2013 The fire alarm should have a direct spur from the fusebox. Within the fuse box, the fuse needs to be marked ‘fire alarm’. Between the fuse box and the fire alarm you need a double poled fuse (white or read without the need for further text). Both the connection in the fuse box and the double poled fuse must be installed by a Part 17 qualified electrician. Quote Link to comment Share on other sites More sharing options...
green-foam Posted November 14, 2013 Report Share Posted November 14, 2013 I have to ask, why would you want to disconnect a life safety system? Quote Link to comment Share on other sites More sharing options...
