1930s original door frame.
Yes, although it won’t be easy!
You can
1.      Fit an approved liner to reduce the gaps.
2.      Relpace the stops and add intumescent system
3.      Pack the frame with hardwood and intumescent
However, you can not reduce the opening by more than 12mm per-side
Yes, its possible but alternatively you could have a fire door custom-made, from a certificated door blank, to fit the existing door frame. Either way, my advice would be to seek expert assistance to make sure everything complies with the relevant standards and regulations.
