Grade A LD1 Fire alarm system outage
Hello,
I am looking for advice on the following situation:
If a Grade A LD1 Fire alarm system in a converted block of flats has a complete system failure and is not working, can the freehold management company ask the residents to stay overnight in the building over the weekend (Saturday and Sunday) until an engineer attends on the next working day?
Thank you in advance
They can ask, but that doesn't make it right! Usually a waking watch is required to cover such instances, usually by an outside contractor, but in exceptional circumstances residents have rallied round to provide it to save costs.
  • 1 month later...
  • Author
Thank you very much for your help so far. Another question has come up, regarding the maintenance of the system. The maintenance used to be done by a fire alarm specialist company registered with BAFE, but has now been moved by management to a general electrician. Does that sounds acceptable?
It would not generally be regarded as best practice to replace a BAFE-certified fire alarm contractor with a general electrician. However, provided the electrician is suitably qualified, experienced, and competent in the inspection, testing, maintenance and fault-finding of fire alarm systems, this could still be considered acceptable.
It depends if they actually know what they are doing - some do as they have done the specialist training that a fire alarm engineer would, sadly many don't and it shows in their quality of work & service. They must be competent.
