Guest Loughlin09 Posted August 5 Report Posted August 5 Hi all, We thank you for reading our post. We have a fire inspection coming up in 5 days. When i did a fire door inspection today, the concealed door closers have been taken out. (This is going to sound bad but- they have been out the doors for over 5 years). Overhead closers have been fitted where required, and a concealed door closer in the cleaners cupboard. However, this means that the other fire doors have holes in them from the concealed door closers which have been removed. So my question is What can i use to fill the holes in the fire doors, Please relate to the pictures provided . I have found so far about: " To fill fire doors, you can use the following materials: Intumescent Foam: Specifically designed for fire doors, it expands to fill gaps effectively. 2 Expanding Foam: Suitable for filling large gaps during installation of fire-retardant door frames. (SafeLink's site) If anyone knows the best place e.g screw fix, that is cost effective please also advice. Here is an example of our timber/wood fire doors, unfortunately i am not at the location at the moment so cant get picture of the holes Quote
Neil ashdown Posted August 6 Report Posted August 6 Assuming the doors are made from timber? You don't say the fire rating for the doors, assuming FD30? You don't say if the self-closers were removed from the top edge or vertical edge of the door? In my opinion: Foams and mastic are unsuitable for filling large holes and voids in fire doors. Use hardwood timber (min density min 640 kg/m3) tightly fitted without any gaps or voids after the repairs have been completed. The very smallest of gaps can be filled with intumescent mastic or fire rated woodfiller. Quality of work should be the same as expected from a skilled joiner, so that once painted the repairs are undetectable without close examination. I wouldn't recommend repairs to the top edge of the door, if its in a life-safety critical location. Replace instead. Keep records of the work carried out and details & certification for the products used. Quote
Mike North Posted August 6 Report Posted August 6 I assume that the removed closers where Percos? Why did you not just cut the chains, problem solved. I don’t think you could certify a repair Quote
Guest Loughlin09 Posted August 6 Report Posted August 6 5 hours ago, Mike North said: I assume that the removed closers where Percos? Why did you not just cut the chains, problem solved. I don’t think you could certify a repair They are older and have more of a bar than a chain. Building was built in 2004/2005. Concealed door closers, i think they are the same as what you are saying. They where taken out a while ago, so nothing to do with me then. Just out of interest, why could i not certify a repair, hole to big? Quote
sarataylor Posted August 7 Report Posted August 7 I’d avoid standard expanding foam it’s not usually rated for fire doors unless it’s a specific fire-rated type. Intumescent paste or filler is much safer. You could also use hardwood plugs if it's a bigger cavity, but check it won’t affect the door's integrity. Definitely worth asking the inspector if in doubt! Quote
Mike North Posted August 11 Report Posted August 11 To certify a repair to a fire door you must know what the original certification was and what is allowed to be done to the door under the certificate if approval. I also don’t think that this would be covered under an Approved Repair Technique Quote
Neil ashdown Posted August 11 Report Posted August 11 Generally speaking, product performnace certification for fire doors does not cover repairs to the fabric of the door. There are certification schemes for repairs and they have limited scope for the extent of a repair. If you are unsure about whether a repair is appropriate, consult a specialist. They can issue a report stating whether the repair is fit for purpose..............or not. Quote
Alex John Posted August 22 Report Posted August 22 Fire door fillers are materials used inside fire doors to enhance their fire resistance. They are typically made of fire-rated cores such as mineral wool, vermiculite boards, or solid timber, which help the door withstand high temperatures, prevent the spread of flames and smoke, and maintain structural integrity during a fire. Quote
Guest Col B Posted September 14 Report Posted September 14 Our 2 storey building front fire doors have just been upgraded to meet 2025 Regulations. Some of the residents front doors with intumescent strips have 2 joined pieces instead of 1 continuous length. dont seem right to me. Any thoughts please. ty Quote
Neil ashdown Posted September 15 Report Posted September 15 End to end butt jointing of intumescent seals is acceptable if done tightly and well fitted. But don't mix different types. This website is worth visiting https://www.ifsa.org.uk/ Quote
