Flat front Door Replacement.
On 17/04/2023 at 18:06, David N said:
Hello
Can anyone confirm the exact situation regarding replacing all Flat Front Doors with FD30s? Is this mandatory?
Regards Dave
No - it depends on the size and layout of the block. If it is deemed necessary as a result of the FRA that looks at these factors then it would be, but not as routine.
