Can anyone tell me the correct guidance to be used for carrying out a fire risk assessment in a childrens home; its in a converted house of 3 floors housing 4 children; im unsure weather to use specialized housing, residential homes, maybe HTM88 or something else....any advice will be greatly recieved?!
I've done several for a Council and the DCLG Sleeping Risk guide with relevant input from the NFCC Specialised Housing ended up being the most appropriate as they weren't care or nursing homes nor private dwellings or HMO's
The consensus along with the enforcing authority was the risk profile of the occupiers, even with staff on site, warranted the more robust basic  measures in the DCLG guide with further influence from the results of person centred FRAs (as per NFCC) as indicated.
Arson, damage and self harm are sometimes considerations requiring anti barricade doors that are also FD30s doors and anti ligature (expensive but achievable). Deprivation of Liberty authorisations and the sometimes higher risk to the service user from being able to abscond creates interesting considerations when it comes to escape fastenings on final exits!
  • 3 years later...
Are there any fire regulations for a small enclosed porch on a children’s home apart from smoke detection and thumb turn locks on the doors? I have attached a picture.
Regards Mark
You would need to review your FRA, but there should be no major impact beyond that you've said depending on the use of the room. You may need to consider emergency lighting if part of an escape route.
  • 7 months later...
Would a two storey semi detached Childrens home need a l1 alarm system fitted. There is one bedroom on the ground floor and three bedrooms on the first floor. There would be a maximum of two adult and two children sleeping overnight.
