Fire door gaps
Hi Can you increase the width of an old  fire door by adding a hard wood lipping to close up gaps? is that legal?
Yes, so long as you carry out the work within the scope of the technical data sheet for the fire door leaf.  Contact the door leaf manufacturer for advice but if you cannot find out who made the door leaf consult a competent person before starting work.
