Height of fire door keep shut, FRA
We are carrying out work to bring firedoors up to standard, following a  FRA,  many of the fire door keep shut signs are 1950mm heigh, this has not been picked up on the FRA, should they not be at 1500mm to 1600mm eye level.
They should, but it's not really a life safety risk (which is the point of the FRA) if they are a bit high so would be considered picky by many. It would never be an issue for enforcement officers who on an audit wouldn't blink twice at it.
