Guest Nick Posted May 23, 2020 Report Posted May 23, 2020 Hi all, Firstly I have since contacted Safelincs and have a replacement unit on the way- thank you so much to the assistance on the phone, it was excellent. I do have a follow up question about our alarms to help me understand what the issue might have been..? Last night our upstairs DETA 1151 IONISATION (manufacture date Nov 2015- house is a new build complete August 2016) smoke alarm went off for the first time, but only the 3 test beeps. This occured intermittently for the following 4 hours, starting at 1am ish. In a household with two under 5s this was worrying of course. There had been no classic chirping regarding low 9v battery at all etc, just these 3 beeps for this period, intermittently. At 5 am I turned off the mains and disconnected the offending unit until I could source a 9v battery this morning. I was assuming low battery was the issue at this point. Upon replacing the batteries in both units this morning the mains green light on both units was on, as it had been before and during the incident- and a quick test confirmed all was well. After about 10 minutes, the problem alarm (one of only two interlinked) recommenced it's '3 chirps' and now the Red LED remained constantly on. The green LED was now off, suggesting somehow I now had no mains to the unit when I had 15 mins before. RCD breaker checked and all other domestic circuits seem normal. The Safelincs assistant recommend the easichange replacement for my model which I have ordered, but can anyone shed any light on what the issue may be? Any help appreciated! Eagerly awaiting the new unit.. Quote
Guest Mike Posted January 2, 2021 Report Posted January 2, 2021 Just had the same problem with downstairs unit. I had another one upstairs so I took it out and brought it downstairs and this one did not make any noise so the fault seems to be with the alarm unit itself and not the mains or battery Quote
green-foam Posted January 4, 2021 Report Posted January 4, 2021 If the smoke alarm has been proven to have a problem, then there is only one thing you can do, change it, as there are no user serviceable parts inside. Quote
Guest Guest Doreen Posted April 9, 2021 Report Posted April 9, 2021 I have the same issue. We've purchased equivalent replacements (Deta 1151 discontinued) from safelincs but still have the same problem, does this mean we have a wiring issue and need to call an electrician ? Quote
Guest Lee Posted April 25, 2021 Report Posted April 25, 2021 I am having same issue,3.30 in morning,jumped out of bed,found top floor unit beeping 3 times,red light comes on every 15 secs.is this the same problem Quote
green-foam Posted April 26, 2021 Report Posted April 26, 2021 Without having the unit to test, unfortunately it is not possible to give you a definitive answer. But I can say if your smoke alarm is 10 years old then you should change it. Quote
Guest peter new Posted May 17, 2021 Report Posted May 17, 2021 i have same problem 2 alarm one bleeps only 3 years old, seems like something wrong with alarm manufacture Quote
Guest Hp reading Posted June 7, 2021 Report Posted June 7, 2021 Similar issue, was installed in a new build 2016. The unit only goes off when it is connected to the mains. If I disconnect it from the main with battery installed it stays quite. Now that I want to order a replacement it says the item has been discontinued and cannot be sourced from anywhere. What a bummer looks like I will have to order a brand new Alarm and rewired the whole house ? Quote
Guest Hp reading Posted June 7, 2021 Report Posted June 7, 2021 On 09/04/2021 at 17:53, Guest Guest Doreen said: I have the same issue. We've purchased equivalent replacements (Deta 1151 discontinued) from safelincs but still have the same problem, does this mean we have a wiring issue and need to call an electrician ? Where did you order the replacement from? Quote
green-foam Posted June 10, 2021 Report Posted June 10, 2021 On 07/06/2021 at 18:36, Guest Hp reading said: Where did you order the replacement from? Hi, "Doreen" has only made the one post so you are unlikely to get a reply from her, but if you read her post again, it does answer your question On 09/04/2021 at 17:53, Guest Guest Doreen said: I have the same issue. We've purchased equivalent replacements (Deta 1151 discontinued) from safelincs but still have the same problem, does this mean we have a wiring issue and need to call an electrician ? That said, even the replacement is now obsolete. You will have to buy a different brand of smoke detector, the downside to this is that as yet no two different brands of smoke detector will work with each other, so that means you will have to change all of them at the same time. Looking on the bright side all non radio interlinked smoke alarms use a 3 core and earth cable, this means no rewiring to do, but you will need to change each smoke alarms plug. Quote
Guest Deta 1153 smoke alarm Posted February 3, 2022 Report Posted February 3, 2022 Why the red light comes on when I put new replacement battery in? Quote
green-foam Posted February 3, 2022 Report Posted February 3, 2022 I can only suggest you take it down, remove the battery, hold the test button in for 20 seconds, then reverse the process. I would also ask, how old is your deta 1153 ? as they are obsolete and it maybe near the end of its life. Quote
Guest Red light on Posted February 18, 2022 Report Posted February 18, 2022 Am having the same problem as Guest Red Smoke since the power outage. Have replaced the battery but the solid red light stays on...it is 5 yrs old from a new build too. Tried the pressing down test button for 30s but no luck. Quote
green-foam Posted February 21, 2022 Report Posted February 21, 2022 Did you take it down, remove the battery then press and hold the test button? If yours is a Deta 1153 they are obsolete, and if the suggestion does not work, then you will have to change it. Quote
Guest Same problem Posted September 8, 2024 Report Posted September 8, 2024 Had the same problem with one of the larms - house built 2017. Contacted manufacturer who recommend I get a new alarm installed as the Delta 1151 is now absolete. Question is, can the hardwired base still be used with a new and different brand and model? How long do these alarms last? And, will we need to to keep buying new ones and rewiring after 'x' number of years or as soon as the alarm becomes absolete? If this is the case one might have to consider using wall mounted alarms. Quote
green-foam Posted September 9, 2024 Report Posted September 9, 2024 Each brand of smoke alarm has its own unique parts, so no, you can not use a "Brand G" smoke alarm on a "Brand K" base. If you read through this forum, Deta smoke alarms did seem to be more troublesome than most. 7 years for a smoke alarm is a bit short. I can only suggest that you change all of your smoke alarms, I would suggest the Aico Ei146e These have a sturdy base, and room to connect the existing cables (No connector block required) The cheapest I have found them is £31 inc delivery Click here Quote
Guest Nigel Posted December 13, 2024 Report Posted December 13, 2024 Hi, our upstairs mounted Deta 1151 interconnected alarm was set off a few days ago and won't stop alarming now. The PP3 backup battery gives 8.5 volts and the red led flashes every 8 seconds with the battery fitted and the alarm off its base. The manufacture date is June 2017. Is it worth getting a new PP3 or is it more likely the alarm is faulty? Quote
green-foam Posted December 16, 2024 Report Posted December 16, 2024 Your alarm is 7 years old, the Deta 1151 smoke alarm is obsolete. I would suggest you change the complete alarm, also if you have any other Deta 1151 smoke alarms I suggest you change those too. Quote
Guest Deta keeps bleeping Posted August 14 Report Posted August 14 I’ve read a few posts and looks like I’ve got deta 1151 obsolete alarms keep bleeping in my house after changing the battery - any ideas what to replace with please as they are all wired Quote
green-foam Posted August 18 Report Posted August 18 There is no direct replacement for the deta 1151, so it is up to you which brand to have, personally I like Aico, as they are very easy to fit, and are reliable, you will have to change all of the detectors you have at the same time. Click me Quote
Guest feedback on the Easichange Posted October 23 Report Posted October 23 Safelincs have a plugin compatible unit quoted for the 1111 or 1113. Got to confirm a replacement for the Deta 1151? Feedback? Quote
Rahel Lock Posted October 27 Report Posted October 27 Hi Safelincs have developed some replacements for the DETA 1111, DETA 1113 and for the DETA 1115 units, but there is currently no replacement for the DETA 1151 so new units will have to be installed. thanks Rahel Quote
