Guest Darren Posted October 2, 2017 Report Posted October 2, 2017 Hi, I'm about to replace our smoke alarms and I believe they are the Ei141. As they are over 10 years old do I need to replace the base as well as the detector? I've looked at https://www.safelincs.co.uk/why-should-smoke-alarms-be-replaced-after-ten-years/ but it does not answer my question. Thanks Darren Quote
Safelincs Posted October 2, 2017 Report Posted October 2, 2017 Hi Darren, As long as the base plate is in good condition and your wiring is sound you can just buy the replacement head. Harry Quote
Guest Kush Posted January 14 Report Posted January 14 On 02/10/2017 at 18:00, Safelincs said: Hi Darren, As long as the base plate is in good condition and your wiring is sound you can just buy the replacement head. Harry What is the reason the Aico bases also have an expiry date on them? Quote
green-foam Posted January 14 Report Posted January 14 Kush, the post you replied to was made 8+ years ago, Darren posed his question/thanks and has never been back since, Harry has not posted since 2020, best NOT to reply to old posts (On any forum) In order to answer your question can you show where it says that Aico bases have an expiry date? Quote
