November 13, 20169 yr comment_9441 Just moved to a new house. has 2 alarms. both E1 150 mains/interlinked and bty back up. Only base left by previous owner. Connecter (3pin and 1 separate pin still intact. Please advice which product l can replace them with. (would prefer same shape if possible. Edited November 13, 20169 yr by JERRY W spelling Report
November 13, 20169 yr comment_9445 Hi Jerry I am afraid the Ei150 series (TL and TLH etc) has just been discontinued. You can replace as follows, though: Ei151 replace with Ei161 Easichange model Ei154 replace with Ei164 Easichange model Ei156 replace with Ei166 Easichange model You will need to change the plug at the end of the cable as well as the base plate. The wiring itself can remain and the new units will work with any remaining Ei150 series alarms. These kits come with a masking plate to cover ceiling blemishes from the old rectangular Ei150 alarm. I hope this helps Harry Report
February 10, 20206 yr comment_16355 Hi, i have the Ei 150 that is randomly and quite regularly beeping. I presume it needs replacing. It’s a mains detector. What can I replace it with for the same fitting please? Report
February 11, 20206 yr comment_16358 Hi Heather, sadly, there are no more Ei alarms being produced with the same base plate. You will need to upgrade with this replacement kit, using the same wiring plus a plate that covers the unsighly mark left by the old alarm. Harry Report
June 14, 20215 yr comment_20455 My EI150 has just come to the end of its life, what model replaces it and does it have the same plug in fitting Report
June 17, 20215 yr comment_20486 The recommended replacement for the Ei150 smoke alarm can be found if you Click Here The base will have to be changed (It has no plug, as the connections are made to the base plate) Report
