Help with certificate
Hi All.
Can someone please help me? I am a Carpenter/ builder and just finish a job which is listed below. the home owner has asked me for a certificate so that I can get paid?
I made it very clear before I started the job that I could not supply a certificate but only those issued by the manufactures?
How do I go about this? Here is the list and details of what I did.
1.. took out existing glass in transom and replace with 7.2 Pyrogaurd. fitted them with hardwood beading, glued, screwed, and 30min fire seal tape both sides.
   All glass are etched I basically followed instruction I found online.
2.. Removed existing 100mm steel hinges and replaced with fire rated hinges with a third added to the centre, so now all doors have 3 x fire rated hinges.
3..Replaced a badly fitted door, like for like FD30 with intumescent strips, sides/top
4.. 2  x doors were cut too short by previous owner, they had wood flooring. so the gap at the bottom were 30mm. so I added a hardwood threshold to get the gap to 5mm.
Thanks in advance, your help is very much appreciated.
Cass
As far as I am aware there are no third party certification schemes for carpenters who fix, repair or modify fire doors, so who ever did the job would not be able to provide a certificate.
Without inspecting your work I would not be able to say it was satisfactory but as you informed your client at the beginning you would not be able to provide a certificate have you considered taking them to the small claims court.
