November 27, 201312 yr comment_5909 Can anyone tell me if Fire Extinguisher ID Signs are needed above every extinguisher?. Could you also point me in the direction of any specific legislation that says this. I am aware the the Regulatory Reform Fire Safety Order states in 13.-(1) (b) any non-automatic fire fighting equipment so provided is easily accessible, simple to use and indicated by signs. Indicated by signs....., could this just be a fire point sign? or could the extinguisher act as its own sign. I cant find anywhere where it states that extinguisher specific signs are needed above every extinguisher. Report
November 27, 201312 yr comment_5912 You are reading art 13(1) b in isolation the first two words in art 13 (1) is "Where necessary" then read (1b). Check out https://www.gov.uk/government/publications/regulatory-reform-fire-safety-order-2005-guidance-note-enforcement for clarification. Report
November 27, 201312 yr comment_5914 Hi Guest_Forest10_* The British Standard BS 5306-8:2012 (a recommendation only) in section 6.1 NOTE 2 states: "The position and type of a fire extinguisher should be indicated on a sign so that, if the extinguisher is removed, this can be identified during a safety inspection, and a replacement ordered." So, as far as the British Standard is concerned, each extinguisher ought to have an ID sign. Whenever I perform extinguisher site surveys now an ID sign is included with every extinguisher. Hope this helps. Regards Shawn Report
November 28, 201312 yr comment_5917 I think the legislation RR(FS)O art 13(1) b is quite clear " where necessary a fire extinguisher sign is required" and the British Standard recommends a FFE sign should be provided but would not a bracket without an extinguisher hanging from it, indicate it had been removed? IMO the decision lies with the Responsible Person whether it is necessary or not. Report
