January 7Jan 7 comment_55413 Hi I have just fitted a fire door that requires a closer on the push side. I don’t normaly like them fitted on the push side as theres greater loading on the fixings, and it is on the fire side of the door. The budget Eclipse door closer that I normally use will not work as the scissor arm rubs on the chunky stop lath on the door lining (even when using the fish plate). Im sure other fitters have a solution to this when using door linings and stop laths? Would a track type closer work? ie could I fix the door closer arm track directly onto the stop lath? This way when the door pushes open the closer and closer arm clear the stop lath. Looking forward to your solutions. Report
January 12Jan 12 comment_55462 The stop lath should not be removed and replaced by a door-closer slide arm track. Check that the budget self-closer you are using has fire performance certification for use in the paralell arm cofiguaration, some come with a push-side kit but even so are only suitable for fire doors in projecting arm (pull side) cofiguaration. Check this out, this company has a few instructional films available. Contact them for more info and with any questions. They also run training sessions. Report
January 14Jan 14 Author comment_55485 Sorry, for clarity I wanted to know if a parallel door closer track can be attached to the stop lath on the lining? Report
January 20Jan 20 comment_55562 Yes it can, but you may need to make the stop lath wider to get a secure fixing. Report
