Guest th34 Posted September 25, 2025 Report Posted September 25, 2025 I have a 30 min fire door for a flat door that has a nightlatch installed. Is there anyway to make this latch fire compliant, for instance by fitting an intumescent fire door lock pack? Or is there an alternative lock that I can fit into the exisiting hole? Thank you for your help Quote
Neil ashdown Posted September 29, 2025 Report Posted September 29, 2025 Fire resistance performance test evidence does exist for some night latches. But compliance also depends of the core-type for the timber-based fire door in question. An experienced fire door inspector should be able to assist you. Failing that, an experienced fire risk assessor may be able to help. Quote
