September 11, 20251 yr comment_53372 any help appreciated - as others have said regs are not clear..im not inclined to spends 100s or 1000s if we dont need to.. Q - will a fire door 43 mm thick be compliant - is there leeway on the 44mm rule...? What is the min a fire door must be thick ? Q - do flat front doors need checking every year ? can anybody perform the check or do you have to hire in 'fire door inspectors..'? thanks Report
September 15, 20251 yr comment_53488 The thickness of the door depends on the relevant certification / evidence of fire performance for the door. Also see Also see https://www.howdens.com/joinery/doors/howdens-spey-35mm-plywood-flush-fd30-fire-door-obj-sku-family-25409973 Refer to the relevant UK Gov fire safety guidance for the type of resirential block inn question eg: https://www.gov.uk/government/publications/fire-safety-in-purpose-built-blocks-of-flats https://www.gov.uk/government/publications/making-your-small-block-of-flats-safe-from-fire Report
September 15, 20251 yr Author comment_53490 so the 44m rule isnt the final say in effect ? You can buy a 35 mm fire door per your link ? Our installer says our door needs replacing despite them passing previous year..they are 42.5 /43mm thick. What about the check being annual - not what im reading in gov advice yet we are told they need doping annually. Report
September 17, 20251 yr comment_53543 So, has the Installer said why the door needs to be replaced? At residential blocks below 11m in height, there's no statutory requirement to inspect fire doors to a particular schedule but there is (under Article 17 of the Regulatory Reform Fire Safety Order 2005) a legal obligation, as you would expect, to ensure fire doors "are subject to a suitable system of maintenance and are maintained in an efficient state, in efficient working order and in good repair". See https://www.legislation.gov.uk/uksi/2005/1541/article/17 Report
September 17, 20251 yr Author comment_53545 The installer advised building management the door is under the required 44mm thickness (its 42-43mm) and needs to be replaced. Even though the previous year it was deemed to be fine but had a couple of minor adjustments! And they insist on annual checks. Thanks Neil. I believe they are wrong on both counts. Report
September 17, 20251 yr comment_53546 If the installer says the door is non-compliant due to the thickness being 42mm or 43mm (rather than 44mm) and requires replacement, they should back that up with the relevant documentation (guidance/certification/product data sheet etc). If they can't, then what basis do they have for making that recommendation? Report
September 18, 20251 yr Author comment_53565 more info on my door - its a notional door 42.8 mm thick was brought up to compliance in 2022 (strips/gaps etc). Now im being told as its under 44 its not thick enough and needs replacing - Im just wondering how they can go from its ok in 2022 to now it being to thin. ?! Report
September 22, 20251 yr comment_53625 If that's the only reason why the latest inspection has found the door to be unsuitable, the inspector would need to back up their finding with the relevant documentation. Report
