Guest Stu Posted June 26 Report Posted June 26 Looking to find a solution of where to rout and install cold and smoke seals on this rebated server room fire door if anyone could suggest? Thanks Quote
Neil ashdown Posted Monday at 10:46 Report Posted Monday at 10:46 Please send image of door in the closed position from inside the server room. Looking for somewhere suitable to locate a smoke seal as unsure there's room for a compression/batwing seal within the existing rebate? Quote
Guest Stu Posted Tuesday at 08:26 Report Posted Tuesday at 08:26 Hi Neil and thanks for your reply. Please see the internal photo of the door. Quote
Neil ashdown Posted yesterday at 16:04 Report Posted yesterday at 16:04 No options for smoke seals on the pull-side so check the rebates to see if the batwing will fit. When these are fitted the door must self-close completely and reliably. There may already be intumescent seals integral to the door leaf behind lipping at the vertical and top edges? Check this before making a groove in the door. If you are fitting intumescent seals though, the smoke seal could be incorporated into those. Quote
