May 22, 20251 yr comment_49303 We have recently had an external Fire Door RA carried out and we have a couple of leaf and a half doors and have Fire Door Keep Shut (FDKS) signs on both sides of the main door - the assessor stated that we needed them also on the 1/2 leaf (on both sides) - is this absolutely necessary? Report
May 28, 20251 yr comment_49422 Is it a bolted leaf not normally in use? If so it's a bit OTT. If its a closer fitted in use leaf then there is slightly more justification. Technically they are right but it's not risk proportionate, won't affect life safety & won't be enforced Report
