August 29, 20223 yr comment_29012 Hi can you advise if 1 Inch door stops mitigate the risk from excessive gaps at the top and sides of FD30S fire doors ? Report
September 7, 20223 yr comment_29278 There is no guidance that thicker rebate stops mitigate the effect of excessive door to frame gaps. Where restricted cold smoke spread is a requirement, effective smoke seals will be necessary. Report
