July 13, 20224 yr comment_27759 Hi everyone.. I live in a basement flat which has a side walkway to my front door..we also have french doors at the back of our flat which lead onto the garden area..At the top of our walkway is a security gate which we keep locked and have done for 21 years... The property freehold is owned by social housing though we own our flat.. We have just come back from holiday and the social housing team have taken the deadlock l lock out of the gate leaving it unlocked not informing us and saying it's against fire regs and we should have a thumb nail lock that we can open from the inside..I said we use this as our security gate and anyone who wants to break in will just reach through the bars I cannot believe they have done this as we can go in the garden at the back or climb over the wall into the neighbours..We can even climb over the security gate.. Any views.As livid.. Thank you James Report
July 18, 20224 yr comment_27880 Is this an external gate not in the actual building? Does sound rather OTT and not covered explicitly by an actual regulation. Report
October 13, 20233 yr comment_39041 Anthony B So sorry not to get back to you earlier..Thank you for your reply. Yes it is an external gate in the side alley that leads up from our flat door to come out the front of the house. We use a key on the keyring we use to lock the flat door to unlock it and can climb over any of the walls if for some reason the lock fails to open ... Many thanks James Report
October 13, 20233 yr comment_39056 It does seem a little excessive! The only possible reason I can think of is that if you didn't have the key you would be trapped too close to the house. Report
