April 27, 20224 yr comment_25404 We have an open plan kitchen and lounge on the first floor of our home - but the ceiling is pitched (height approximately 5-6m). Do we need to have both a smoke and heat alarm fitted in the top of the apex? Or would a single heat alarm suffice? Report
June 8, 20224 yr comment_26659 I cannot give definative advice without knowing the layout of the premisses I would need a detailed description or preferably a detail sketch. I am asumimg that your house is an upside down design, upstairs is living and the ground floor sleeping. The upstairs should be a heat detector and should be separated from the downstairs by 30 minutes. The downstairs should be smoke detectors. Report
July 13, 20223 yr Author comment_27762 On 08/06/2022 at 22:42, Tom Sutton said: I cannot give definative advice without knowing the layout of the premisses I would need a detailed description or preferably a detail sketch. I am asumimg that your house is an upside down design, upstairs is living and the ground floor sleeping. The upstairs should be a heat detector and should be separated from the downstairs by 30 minutes. The downstairs should be smoke detectors. Thank you Tom - much appreciated. Report
