December 16, 20214 yr comment_22906 I have a L3 system in the communal area of a block of flats. my question is does the electrical riser cupboards and water riser cupboards class as a room opening onto the escape route? and will need detection? Report
December 16, 20214 yr comment_22913 Potentially yes - anyone using common sense would want to cover the electrical riser anyway, whereas there would be an argument to exclude the water riser as a variation if it only contains water pipes. Report
August 1, 20224 yr comment_28243 I deal with this topic now in the block of flats thanks for clarification. Report
