MS
If i live in an apartment block with 9-18 floors should there be Manual call points on each level, as the one i live in only has them at the final exit doors on the ground floor?
What are the legal requirements?
If built as stay put to Building Regulations you wouldn't expect any call points (or alarm sounders) - whilst you might have seen them in other purpose built modern blocks they aren't actually required.
