Orbital Posted February 13, 2020 Report Share Posted February 13, 2020 Converted house with 4 flats. Pre 1991 One flat is a basement flat, with a separate entrance.You then have a ground floor flat, first floor and second floor flat.All owner occupied. The building has a small communal hallway, and two flights of stairs. The guidance seems to be that a Type LD2 Grade A installation is required, for the communal area. The basement flat is not connected to the communal area, and has its own entrance. Will that flat require a detector/sounder installed? Thanks Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted February 13, 2020 Report Share Posted February 13, 2020 If the fire separation between it and the upper floors is OK then it wouldn't - but if (possible as a pre '91 conversion) it isn't then it'll possibly need heat detection off the common system Quote Link to comment Share on other sites More sharing options...
Orbital Posted February 14, 2020 Author Report Share Posted February 14, 2020 Thank you for the reply. Quote Link to comment Share on other sites More sharing options...
