August 8, 20188 yr comment_12423 I manage a small block of 4 flats, 2 on each of the 2 stories of the purpose-built block. The block is free-standing and not attached to neighbouring properties. We have an emergency lighting system installed but is it really necessary for such a small block? And having it, does it need to be expensively tested each year by a qualified electrician? Report
August 8, 20188 yr comment_12430 If it's there then yes (if it was built in the last 20-30 years it would have been put in as a Building Regulation requirement) and a 3 hour test on a small block of flats shouldn't be that expensive you should get other quotes. If it wasn't there because it was an old development then due to size it would be recommended (but a lower priority than fire door issues) as oppose to a high priority action. You have no option but to maintain it appropriately, it would be an offence not to do so. Report
August 10, 20188 yr Author comment_12441 Thanks, Anthony. We'll accept the situation but see if we can get another quote for next time it's tested. Report
