August 11, 20179 yr comment_10641 Dear all. I have a error with Kidde AEGIS Single Hazard Agent Releasing Panel. 120/240 V, 50/60 Hz AC Input. With 7 Initiating, 3 Notification, 2 Release Circuits & 4 Relays in Red Enclosure (84-732001-001). This is Primary PSU Output Voltage. I replace the power supply and battery, check Voltage Input is 230V and Output 24V. I think everything is correct. But when i press system reset, the light of PSU TBL are still on. Plese tell me why and how to fix this. Thanks so much. Report
August 15, 20179 yr comment_10668 Check out http://psfirefighter.proboards.com/thread/112/fixed-extinguishing-systems?page=1 they may be able to help. Report
August 15, 20179 yr comment_10670 Also check out http://firealarmengineers.com/1 they may be able to help. Report
