Smoke Alarm Problems
Hi all,
I am a high school engineering student and am working on the downfalls of smoke alarms in hopes of developing a final project by the end of the year. Would you all mind taking my survey? Here is the link: https://www.surveymonkey.com/s/XGHSJRKthank you all so much! :)
On line surveys such as yours do not give good results, since you can "adjust" the way you look at the figures to give the results you want.
I wish you luck with your project, but ask yourself this.
At the end of the day, can you really make a better smoke detector that is affordable? If its not affordable it will be a "gimmick"
