November 22, 201213 yr comment_5093 Is it within the regulations to fit a door closer to a outward fire exit door which has an internal single latch push pad and an external mechanical keypad codelock? Report
November 22, 201213 yr comment_5096 If this is a final exit door I see no problems with this arrangement, moreover if you need security from the outside then the self closer is required to achieve that. The means of escape from the premises is from the inside to the outside, through this door and using the push pad means you do not require the use of a key. Report
January 24, 201313 yr comment_5236 I cannot see why not, providing it doesn't interfere with the door opening to its fullest extent. Report
