October 6Oct 6 comment_56201 I am having a carpenter fit a new door to my attic conversion and he mentioned it had to be a fire door but that it also needs have a perko.I have ordered the door but am unsure of whether or not i legally need a perko?can someone advise?Thanks Report
October 7Oct 7 comment_56203 If the property is a single dwelling in a two-storey house that has been converted into a three-storey house with a loft conversion, there is no requirement for a door closer, although the door may need to be fire-rated to protect the escape route.In a dwelling, door closers are generally only required on the door between the house and an integral garage.If the property is an HMO, a flat, or a commercial premises, self-closing fire doors will normally be required, and the closer should be a suitable fire-rated/certified device. Report
