October 2Oct 2 comment_56191 We have a medium-rise block of approx 15m with through-the-wall letterboxes in the communal entrance lobby. The boxes are almost entirely metal, however, they are not fire-rated. Do they need to be? The only bit that isn't metal is a small ppening covered with palstic for the residents' details on the entrance lobby side. Thanks. Report
October 2Oct 2 comment_56194 11 hours ago, Guest Matt said:We have a medium-rise block of approx 15m with through-the-wall letterboxes in the communal entrance lobby. The boxes are almost entirely metal, however, they are not fire-rated. Do they need to be? The only bit that isn't metal is a small ppening covered with palstic for the residents' details on the entrance lobby side. Thanks.Your fire risk assessor should have covered this in your FRA, are these in the external wall? It may not be a requirement at all, I'd need some more info and ideally a picture of their location. Report
October 5Oct 5 comment_56196 Thanks. Yes, they are in the external wall. They are installed in the wall adjacent to the communal entrance door. The wall is a masonry cavity wall and there is no cladding or balconies.Here is a photo of the side accessed from the internal common areas. Report
October 5Oct 5 comment_56197 No exposed cavity, metal limed with a solid door on the inside of each box, I wouldn't be too worried. Report
October 5Oct 5 comment_56198 Thanks for the help. This is a photo of the internals showing the metal lining and that the cavity isn't exposed. Report
