  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
FRA Mixed-use premises. Commercial (takeaway) ground floor & Residential (single flat) First Floor
I have a 2 storey mixed-use premises, consisting of a commercial unit (takeaway) on the ground floor and single residential unit (1 bed flat) on the first floor. There are no common area and separate entrances to both units.
I am aware that I require a commercial FRA for the takeaway downstairs, but I am unsure as to whether I require a residential FRA for the flat as there are no common areas and both have separate entrances. I understand that the Fire Safety Act 2021 states that an FRA is required for building containing two or more dwellings, regardless of whether there are common area or not, but does not mention mixed-use in this way.
Basically, do I need an FRA for the flat?
  • OJ_28 changed the title to FRA Mixed-use premises. Commercial (takeaway) ground floor & Residential (single flat) First Floor
No. The commercial FRA should consider the effect of a fire there on other relevant persons (flat above) but the flat does not require an FRA as it is a single private dwelling in a block of one.
