A two-foot square timber fronted riser cupboard on a stairwell of a 5-storey residential block of flats contains three waste pipes and three electric supply cables running up through all floors. The hinges are not fire-rated, the door is 18mm thick with 10mm stops. No combined seals. Is there a need to better protect the escape route?
